2010D Generator Not Charging
Bob in NH
11-06-2005 18:46:38
The generator on my newly acquired 64 2010D Row Crop doesn't charge. Previous owner claimed it had just started coming on in the past month. I have checked connections at generator and starter, tried polarizing generator, jumped the field terminal to ground, and finally removed the generator, opened it and cleaned up everything. Generator appears to check out OK with a multimeter on the bench. Brushes look good and are free. Wiring does not appear to be shorted anywhere. I haven't gotten to the regulator yet - appears that it is hidden behind the dash.
Tonight I had the lights on and after they had been on for a while (8-10 minutes?) the breaker evidently tripped and they went out. When this happened, the GEN light on the dash went out and stayed out until I turned the light switch off. After the breaker cooled and reset, I turned the lights back on and GEN light stayed on, until the breaker tripped again and the process repeated.
Where can I get a copy of the wiring diagram for this tractor? Does anyone have any ideas of what may be happening, or what should be checked next? If the light circuit was actually shorted, I would expect 4-5 sealed beams to trip the breaker sooner. I suspect there is a direct relationship between the breaker tripping issue and the no-charge problem.
John T
11-07-2005 06:03:13
 Re: 2010D Generator Not Charging in reply to Bob in NH, 11-06-2005 18:46:38
Bob, I take it she still didnt charge when you dead grounded the gennys field post corect??? If it didnt, try leaving the Field shorted and by pass jump the VR"s cutout relay by temporarily shorting its BAT terminal to its GEN (or ARM) terminal n see if she charges then, if so but not otherwise, I suspect the VR"s cutout relay is bad or its contacts burned n carboned. When you ground the gennys field and by pass the VR"s cutout relay, you basically take the VR out of the equation so if shes still not charging its EITHER a bad genny or a short in the wiring as you also suspect.
You may wanna try the motor test to check the genny. Remove the belt and wires and have the Field grounded and apply voltage to the gennys Arm post and it should spin indicating the armature n brushes are likely good. Then unground the Field and it should run faster indicating the Fields are likely okay.
Of course, if there a bad short as you suspect, its sucking up any curent the genny may put out and that, not the genny or VR, is the problem. Try disconnecting any loads like lights etc which are usually fed off an ammeters load terminal or the BAT terminal on the VR (but not the wire from the BAT to the battery/starter) or another hot source n see what happens.
If she charges okay until you add some loads (lights etc) they may have a partial short.
John T
Bob in NH
11-07-2005 20:06:15
 Re: 2010D Generator Not Charging in reply to John T, 11-07-2005 06:03:13
Thanks John T. everything I did didn't change the no-charge problem. I forgot to try the motor test when I had it off before, but intend to do it the first chance I get, probably this weekend. I also really need to take the dash and panels off to get to the regulator (I think it is behind there) and the rest of the wiring. This tractor has idiot lights for Gen and Oil Pressure, so I need to see how that is wired. I had also thought of removing the armature wire and connecting an ammeter in series directly to the Neg terminal on the battery (Positive ground) and checking to see if this shows any charge. If I am thinking correctly, this would eliminate the rest of the wiring and would show if the generator is putting out, which I think it is.
The old 2 bangers I have with 3-pole generators and cut out are so much easier to deal with!
Bob
lonzo
11-06-2005 19:12:03
look for rubbed places in the wiring loom, remove the ground cable from the battery and hook and test light from the cable lug the post and turn on the key, your light should light, if it doesn't check out the test light, now watch the light and wiggle the wires and some where some place you will see the light flicker,there is the location of a problem with the wiring. repair and recheck for more problems.
