60 transmission questions
chrisfromsolitude
11-06-2005 12:39:10
Here is what happened. My 60 will slip out of gear when transmission starts to "push" the engine, or the load is removed from the transmission. If there is a load on it, it is fine. I took the reduction gear shaft bearing cover off and the shaft will move back and forth about 1/4 of an inch. When the shaft is out the trans won't catch, but when you hold it in it will. I took the first reduction cover off and removed the pto gear and reduction gear. I took the top off the trans and the reduction gear shaft wobbles pretty bad in it's bearing but the bearing is good and tight. I can't get the reduction gear shaft to do what ever it was doing before I took the gears off. The teeth on the gears don't look too bad at all. However, I think the bearing in the end of the reduction gear shaft that supports the sliding gear shaft may be out. I can't tell yet. My question is does anybody think that would cause the trans to kick out? The gearshift stayed in the shift quadrant too. It's like the power to the trans was gone. There were gears grinding a little but they sounded like they were outside on the reduction gear. It looks good though. Just got it apart this morning and expected to find something wrong but that wobbling shaft is all I came up with. Thanks for any thoughts.
DIesel Don
11-08-2005 16:48:31
 Re: 60 transmission questions in reply to chrisfromsolitude, 11-06-2005 12:39:10
It sounds to me like the bearings for the tranny main shaft are bad. I just recently rebuilt a JD A tranny and they are just about the same a 60. The bearings were so bad in mine that the stub shaft behind the first reduction gear wobbled out the splines and I had to get a new stub shaft. It doesn't sound like you are in for that much trouble yet. You will enjoy getting in to this tractor tranny. The whole thing comes apart through the sides and the top. Get a good service manual and don't be afraid to take some pictures as you dissassemble it.
chrisfromsolitude
11-09-2005 10:26:31
 Re: 60 transmission questions in reply to DIesel Don, 11-08-2005 16:48:31
I got time last night and got the trans all took apart. My bearing was loose on the stub shaft, the countershaft bearings were loose enough I am going to replace them while I'm in there. It moves back and forth about 1/4 inch or so. I'll just put all new bearings in it and see what happens. Thanks to all you guys for your input. I'll let you know if it works when I get it back together. Thanks again and yall have a nice day.
430WLPG
11-06-2005 17:07:36
Loose bearing and/Or bearing preload will cause your problem,And by the way from what you said it"s the hi-lo part of the trans. that is slipping out, the first reduction gear that shifts from hi- to lo so if it"s loose it"s where the problem lies. Did you notice if it would jump out on one side of the quadrant or the other?And it could be as simple as a broken detent spring.
CLW
11-06-2005 16:53:52
In the search at the top of this page, put in "jumps out of gear" There are about 120 post on this subject. Look at the ones on the 50 which should be about the same as the 60.
CLW
CLW
11-06-2005 16:53:16
CLW
Mike M
11-06-2005 14:29:36
I haven't found a 2cyl. tranny yet that didn't need something. Afterall the youngest ones are 45 years old !
