Pony motor distributor wiring
superfarmer
11-06-2005 09:46:44
I just got a new set of coils for my 80 pony motor, but there were none in it when i got it. I would think that the ring terminal goes to the condensor and the spade goes to the power supply, but don't want to kill them, as I've heard this is easy. Also, should there be a resistor on the ignition wire on this one? What voltage is desired? Thanks.
Dave
superfarmer
11-07-2005 17:37:30
 Re: Pony motor distributor wiring in reply to superfarmer, 11-06-2005 09:46:44
Thanks guys, looks like it'll work now. Just have to get some switches in there and not burn em out and see if this little pony's got some life left yet!
robertq
11-06-2005 14:52:15
search archives ,put in pony coil in search box.alot of info in there from past posts.leaving key power on a none running pony,if points are cloised will cook that coil in a short time.FIT and Clooney had a good talk in archives about a safety circuit,that will protect coils from accidental power left on situations.I know I cooked a coil once an did myself a favour and wired in a safety switch.
F-I-T
11-06-2005 16:32:16
 Re: Pony motor distributor wiring in reply to robertq, 11-06-2005 14:52:15
Here's a link to the pony coil protection circuit.
Frank
superfarmer
11-06-2005 11:43:25
 Additional Problem with wires!! in reply to superfarmer, 11-06-2005 09:46:44
Never worked on one of these before, but how are the plug wires supposed to attach to the coils? There"s a cone shaped end on the old wires and the ones that came with the kit, but the coil just seems to have a pin inside the hole with what looks like the threads of a wood screw. Am i missing something? Thanks....
Glen in TX
11-06-2005 12:28:42
 Re: Additional Problem with wires!! in reply to superfarmer, 11-06-2005 11:43:25
Original type coils used the cone type connector that pushed and snapped in place. For the screw type you are describing just cut that end off and twist and thread the wire in. Pony distributors were designed for 6V only. Do NOT get 12V on them or they will be fried.
F-I-T
11-06-2005 11:43:02
SF:
The 80, like the 70D, used a dropping resistor in the line, mounted on the ignition switch. It was supposed to provide around 4.75 loaded volts to the coils. These newer imported coils that are plastic covered seem to like a bit more, so I customize mine by playing with the resistor length until I get the voltage up around 5 to 5.2V I think on the 80 there was also a direct by-pass line to the distributor from the starter mounted switch, back fed to the dash push button. This provided direct battery voltage to the distributor during the excessive draw of the starter on the battery during cranking. Since at this moment the battery voltage tended to fall to below 6v, it helped a great deal in getting the cold pony to fire.
I have included a picture from the parts book in hopes that that gets you what you need.
Frank
WeirdDeere
11-06-2005 17:40:59
 Re: Pony motor distributor wiring in reply to F-I-T, 11-06-2005 11:43:02
Yes there was a bypass for full voltage on the starter switch. It helps to start the pony, especially if you have the oil pressure switch like on mine.
Brandon
F-I-T
11-06-2005 13:25:51
 Sorry, forgot the photo in reply to F-I-T, 11-06-2005 11:43:02
third party image
nt
