2550
Gatz
11-05-2005 18:06:26
Not a regular Green guy, but wanted some advice.
There's a 2550 2wd 4 cyl diesel that will be coming up on a state surplus auction (hard to tell when, tho'). It looks ok externally; I don't know if it's possible to have a closer look and see if it runs or just why it was deemed surplus. Maybe hours?
Looks like it was used for mowing; it has a CatII 3pt, PTO, and 2 remotes. It's painted industrial yellow and has a ROPS frame. Everything seems to be there and not all busted up, with a few minor details that can be easily fixed.
Is there anything that a person should be aware of on these?. I read a few posts about the cost of replacing the main clutch on a 2550. However, I think I can handle a split and the labor end myself; so it would be parts if that were the problem.
Any caveats ? Any ideas on prices at an auction?
TIA, Gatz
Bigboy
11-06-2005 04:57:47
 Re: 2550 in reply to Gatz, 11-05-2005 18:06:26
If I'm thinking straight this early, the 2550 has the 239 cu. in engine. It's used in several different applications, including (with a turbo in some cases) back-hoes, and various farm tractors from Deere. It's a good motor.
Like any wet-sleeve engine, they needed good maint. regarding the cooling system from day one. (Being a "state tractor" it probably got that) Coolant tends to become acidic over time. That. combined with cavatation in the block, and to some extent, dirt and rust particles in he cooling system, they're proned to electraulysis (also known as wet-sleeve pitting) The cylinder sleeves can end up with small pin holes that let all the coolant drain into the crankcase. This is not a good thing. It's no more likely to happen with that model tractor than any other wet sleeve engine, but something to look out for. Most visible signs are grey to milky discoloration of the engine oil, and moisture/steam coming from the crank-case breather tube while running (That's towards the rear of the engine, on the left hand side, opening about the bottom edge of the block)
The costly part involved with clutch changes would arise if that tractor is equipped with the hydraulic shift Hi/Lo transmission. If it has the more conventional 4X2 shifter, it's no more expensive than anyother tractor of it's type to re-clutch.
Does it have live power, or is it independent PTO? The latter isslightly more trouble when time to work on, but in my opinion much better to own. If it's spent most of it's life as a mower tractor, check PTO operation well. That's where you're most likely to have troubles, again, in my opinion.
Other than that, just check all the normal things on a used tractor.
matthies
11-05-2005 20:22:44
Being a state employee myself, we do send some items in that are still good and just don't use enough to keep around. And then some get sent to surplus because the item is junk. The department should let you run it if you call and ask to test drive a few days before the sale and also might give you a number to the shop that was using the item. chris in Nebraska
