Gresen loader valve
Lambert
11-05-2005 16:31:48
I have a Gresen valve I would like to use for my 46A loader on my 2510. The valve was used on a 47 loader on a 1020. The only number I can find on the valve is 2712, which I presume is the model number? Will this valve work ok on my 2510 since it worked on the 1020, or do the 1020 and 2510 have different type of system, ie. closed versus open? I don't want to burn up my pump. Thanks for any advice you might have.
Tx Jim
11-06-2005 04:09:14
 Re: Gresen loader valve in reply to Lambert, 11-05-2005 16:31:48
Lambert,both tractors are closed center and valve will work if it worked correctly on 1020.Tx Jim
Lambert
11-07-2005 09:20:00
 Re: Gresen loader valve in reply to Tx Jim, 11-06-2005 04:09:14
Thanks Jim.
J. Schwiebert
11-05-2005 23:25:41
2712 is the Gresen Casting number. The model of the valve is an SP and then what ever options the valve has. No doubt it has the closed center plug now as I think your 1020 is also closed center. I have never seen a 1020 in this neighborhood. I do have some Gresen literature as when Dana owned Gresen we used to cover them in the Gresen product schools. Send me a U S mail address and I will copy it.
Lambert
11-07-2005 09:18:52
 Re: Gresen loader valve in reply to J. Schwiebert, 11-05-2005 23:25:41
Please send to: Lambert Fleck, 13909 Harris Rd., Athens, IL 62613. Thanks.
J. Schwiebert
11-05-2005 23:18:12
The 2712 number is the casting number. The model of the valve is a basic SP. It can have some options. I am not familiar with your 1020 tractor as there are none around here. If you need more Gresen information for the Valve send me a U. S. mail address. They were all manufactured as open center valves with an optional closed center conversion plug which I would think your 1020 tractor has. The 2510 is closed center. There were more of those around here. This is rowcrop tractor country.
