47' B Fuel Filter
CLK n Cypress
11-05-2005 14:46:41
Just returned a brand new fuel filter that was leaking a drop about every other second purchased from Deere. No burrs on the seat where the brass shut off contacted it & it still dripped out the outlet port. Just came in with a second one & when I pressurize it, it leaks. Hopefully some has a idea to remedy this. Thanks, Clay.
F-I-T
11-05-2005 14:49:20
 Re: 47' B Fuel Filter in reply to CLK n Cypress, 11-05-2005 14:46:41
Check the deck where the glass bowl contacts the gasket. I have had two that had a bow in the seat and would never seal. It's tough to see at first glance.
Frank
CLK n Cypress
11-05-2005 17:35:13
 Re: 47' B Fuel Filter/Sediment bowl assembly in reply to F-I-T, 11-05-2005 14:49:20
F-I-T, The fuel is not completly shutting off @ the valve just after it leaves the fuel tank. This why I ordered the whole sediment bowl assembly or Fuel Filter. Thought about steel wool but need to make a jig to be plum with seat. Maybe a bit of lapping compound. Thought maybe ya'll had run into this. This is my first B.
Clay.
F-I-T
11-05-2005 17:55:55
 Re: 47' B Fuel Filter/Sediment bowl assembly in reply to CLK n Cypress, 11-05-2005 17:35:13
I though you were saying it was dripping off of the sediment bowl. So the valve won't seal tight? I don't know...look it over for flash inside by the seat. If you can spin the needle into the seat with some lapping compound it might improve.
CLK n Cypress
11-06-2005 06:56:53
 Re: 47' B Fuel Filter/Part#AA4295R in reply to F-I-T, 11-05-2005 17:55:55
Frank, Guess I was preturbed towards the second new part doing the exact same thing and didn't word it correctly. Thats right, where the brass shut off valve meets the pewter seat is the place thats letting fuel pass by it. This a very minor problem, one thats so simple it's hard. Thanks to all for the help in the past, presant & future. Clay
Lee B
11-06-2005 16:16:12
 Re: 47' B Fuel Filter/Part#AA4295R in reply to CLK n Cypress, 11-06-2005 06:56:53
Perhaps putting a custom grind on just the right sized drill bit would bring that zinc seat into compliance? It's a hassel not being able to buy stuff that is supposed to work in the first place but them's the breaks.
F-I-T
11-06-2005 13:27:40
Yes, I know what you mean on things like that. Unfortunately, stuff that comes from die-cast molds these days seems to be less and less true and clean.
Frank
CLK n Cypress
11-07-2005 06:47:00
 Re: new part rr in reply to F-I-T, 11-06-2005 13:27:40
Just trying to get the B back to some work. One day soon the new part is gonna get operated on. But many thanks to LEE B, Frank & all. Clay.
