JD 4310 Stops Moving
Stretch14
11-05-2005 12:10:29
I have a 2004 JD 4310 tractor with E hydro that just stops moving when driving in any gear. The front end loader still works as does the rear 3pt hitch. Eventually it is able to drive again but then it goes out again. Can anyone help?
NathanRed
11-05-2005 18:44:35
 Re: JD 4310 Stops Moving in reply to Stretch14, 11-05-2005 12:10:29
More than likely it is a electrical problem. If the seat safety switch or the wiring that controls it is shorting out it would cause it to do that. The next time it does it jump the seat switch to see if thats the problem. Another thing that it could be is the park brake switch and wiring. If the tractor thinks the park brake is on it will not move. Let me know what you do right before it quits if there is omething that makes it quit every time.
