Help with L clutch please!!!!!
jas
11-05-2005 11:41:54
I have a 1940 L with the herc. engine and a clutch that will not release. I have had the clutch out many, many times and I can't find out why. The clutch fibers are tight and it runs true if you put it on the splines and spin it. Splines look good both male and female. Disc mooves freely on splines. The pressure plate looks ok. Fingers are set even. By setting it on the floor and pushing on the fingers you can see the plate lift. I've adjusted the foot pedal so the throwout bearing contacts the fingers almost immediatly when pushing on the pedal. The last time I had it apart I added .060 washers between the flywheel and the pressure plate to give the disc more room. Worked for a little while and now I'm back to the same problem. Still it grinds when you try and put it in gear. It gets worse the longer it runs. I plan to send the assembly in. Why? Because of lack of something I have not done. Any other options?????
Mike M
11-05-2005 13:11:17
 Re: Help with L clutch please!!!!! in reply to jas, 11-05-2005 11:41:54
Had a similar problem on a LA. Could not shift without grinding.This was after just rebuilding the clutch. Pilot bushing looked ok ? lubed it up and left it alone. Turns out I had to buy a new pilot bushing end of problem.
jas
11-05-2005 17:24:29
 Re: Help with L clutch please!!!!! in reply to Mike M, 11-05-2005 13:11:17
I believe that is my problem too. I ended up putting the motor back in without the clutch or the pressure plate and running it for about 5 minutes. You could begin to tell that the driveshaft was turning faster than what it was when I first started it. After I shut it off the driveshaft turned much harder. I measured the pilot and the input shaft before and after, the readings were the same but I guess that there just isn't enough clearance. So, I will polish them both up and maybe it will work. The tractor has always been this way since I bought it. Very annoying!!!!!
Mike M
11-06-2005 05:06:43
 Re: Help with L clutch please!!!!! in reply to jas, 11-05-2005 17:24:29
I'd get a new one if yours is the same as the LA ? I figure that since it is an oilite bushing all my old ones built in lube was gone from age.A new one had fresh lube and it worked great !
