4630 Air Filter Warning Light
pbutler
11-04-2005 07:58:44
Whenever I run my 4630 near full throttle-or the govenor kicks in when pulling hard the air filter light on the console comes on.
I have replaced both the outer and inner filters with no difference.
Is this something I should worry about? Sensor going bad or some turbo issue or something?
Roger in Iowa
11-05-2005 12:25:29
 Re: 4630 Air Filter Warning Light in reply to pbutler, 11-04-2005 07:58:44
Check the air inlet to the filter canister. May have a mud dobber's nest built up in the intake.
Roger in Iowa
lonzo
11-04-2005 17:02:01
nothing is wrong, the filter sencer is a little off, remove it and look at the bottom of the sencer and you will fine a screw head turn it in 1\2 turn and try it out. if that doesn't work get a new one,
