B LIFT OIL IN CRANKCASE????
ZANE
11-04-2005 07:01:42
What do I need to do to prevent the lift oil from migrating into the crankcase on my 1937 model B John Deere. I want to use the lift for a special project but the oil goes into the crankcase in a few days and then the crank seal starts throwing oil when it get way over full.
Please Email me
Zane
Mike M
11-04-2005 10:06:14
 Re: B LIFT OIL IN CRANKCASE???? in reply to ZANE, 11-04-2005 07:01:42
No way lift oil can go directly into the crankcase. It may overfill the tranny and then tranny oil and it mixed could maybe get there ? Check for gas leaking into the cylinders past the rings.
Kent Petersen
11-04-2005 17:41:45
 Re: B LIFT OIL IN CRANKCASE???? in reply to Mike M, 11-04-2005 10:06:14
Mike do you have live hyd pump mounted betwen gov&mag if you do it is your problem
Mike M
11-05-2005 13:17:43
 Re: B LIFT OIL IN CRANKCASE???? in reply to Kent Petersen , 11-04-2005 17:41:45
I guess if he has a live pump added on this could be it ? I think the JD add on ones have a weep hole so when the seal blows it runs out. At least that's what happened on the neighbors A when it blew.
ZANE
11-04-2005 17:19:38
I want to know what I need to do to keep the hydraulic oil in the hydraulic system and it not just drain out into where ever it does go. I will check the differentail transmission housing for over full but I do know for certain that it goes into the crankcase and over fills it from the hydraulics.
Zane
F-I-T
11-04-2005 09:35:18
I"m not sure that there is a way for Powr-Lift oil to get into the crankcase?!?
A leak at the internal cylinder will put that oil into the rearend oil, but crankcase oil....that"s a new one on me. Is the rearend oil so full that it is running out of a shaft sheal and into the first reduction cover or something like that?
Frank
