Gear lube
FredWi
11-04-2005 06:31:50
What does everyone use for gear lube in their old JD tractors? I have read in the archives here that some say to use GL 1 but I cannot find
any, all I can come up with is GL 5, is that gonna do any harm to the gears or bearings?
FredWi
11-18-2005 07:17:59
 Re: Gear lube in reply to FredWi, 11-04-2005 06:31:50
Thanks everyone.
deereford
11-16-2005 17:55:52
NAPA has GL-1 and it's less expensive that GL-5.
John in IN
11-04-2005 17:32:19
You should use only GL-1 gear lube. The GL-5 has some additives that eat up brass and bronze. Also GL-1 sticks to the gears better and lubricates the upper gears in the tranny. I buy mine from a local oil supplier. They stock 90 wt. and can order 140 wt. Also there is an add in Two Cylinder magazine where you can buy 140 wt. Check the phone book for oil/lube supply houses and do some calling. There is info on this subject on the Chevron internet site. Good Luck
JD manSD
11-06-2005 15:13:59
 Re: Gear lube in reply to John in IN, 11-04-2005 17:32:19
I have used GL5 for many years no problems. eating brass&bronze sounds BS to me I would not use 140 in place 90 it is way to heavy in cold weather
jgc
11-04-2005 16:02:50
I was told to use 140 weight gear lube because the old seals tend to leak and 140 is very thick. A local oil and lube distributor got it for me.
It smells just like the 60 year old gear lube that I drained out of it.
Regards,
Jon
