3020 clutch replacement
mike
10-26-2003 14:21:15
Yesterday I pulled a 3020 gas with a syncro trans into the shop for a clutch replacement.splitting it was no problem but now im stumped.How do you remove the two release bearings?The small one will come off with a puller but then the larger of the two wont fit over the hub that the small one rides on.I cant see what attaches the foot clutch cross shaft to the release bearing to disconnect it either.Also the trans and pto input shafts move up and downabout 3/4 of an inch .Is this normal or is the front trans bearing out? Thanks in advance Mike
G-MAN
10-27-2003 05:07:30
 Re: 3020 clutch replacement in reply to mike, 10-26-2003 14:21:15
You also be well advised to replace the input shaft seal while you're there. It fits around the outside of the end of the outer shaft, and seals around the end of the inner shaft. Also makes sure you properly re-orient the release bearing when you go back together, so that the grease zerk is in the proper location.
twopop
10-26-2003 16:03:06
pull hard on the small part that the bearing rides on.it is a slight press fit and should come out with a pull then you can get to the pto bearing.the movement in the main shaft should not be a problem.the pilot bearing holds the shaft straight when the tractor is together.make sure that the outer shaft fits into the pto clutch plate when you slide the tractor together and dont force it.do not pull the tractor together with the 3/4 bolts.you can use the bolts,only,when the two halves are within a 1/4 inch of each other
