720 diesel oil out of exhaust
pd
11-03-2005 07:37:47
i have a 720 i just bought and it puts out raw oil out of the exhaust pipe. can you tell me if this is the valve guides?it wouldn't be the rings would it? are the valve guides something i can press out and in myself? where can i buy them?thanks for the advice paul
buickanddeere
11-04-2005 06:19:56
 Re: 720 diesel oil out of exhaust in reply to pd, 11-03-2005 07:37:47
Try fresh injectors and running the tractor at 195F. Along with a session of full power/full rpm operation. Make certain therer is ZERO restriction through the ENTIRE air intake system. There are no seals on those intake guides. A vacuum will draw the oil right in. You might get lucky. Ruined injectors and plugged oil bath aircleaners are a dime a dozen. If nothing else these will need to be checked and repaired anyways. The cost is cheap and the work isn't too tough to take.
Coastie Jim
11-03-2005 09:06:24
PD,
I am in the middle of as F-I-T put it. Injecting alot of money in my brothers 730Diesel for the same reason. It was slobbering oil out the stack as well. Upon tear down it was discoverd that oil was getting past the rings into the combustion chamber. The left exhaust port was caked with oil and the valve seat had so much oil & carbon on it the valve wasn't able to close fully. I can't rule out guides as a contributing factor but not like the full cause. This one's rings were shot and the cylinders in need of a .045 bore job and new pistons. The valve giudes aren't difficult to change but measure them first. I found these to be with in specs. You can purchase pistons, rings, and most other parts right from a John Deere Dealer. Good Luck! If you need more help just post a message. These guys are awesome and the knowledge base is infinite.
F-I-T
11-03-2005 11:15:38
 Re: 720 diesel oil out of exhaust in reply to Coastie Jim, 11-03-2005 09:06:24
CJ:
One reason I seldom worry about valve guides as a contributing factor to the slobbering is that there is no manifold vacuum on a diesel to suck it into the combustion chambers.
I replaced the ones in my 70D head at 7,000 hours as they were just sloppy, and since I put in all the valves and springs and keepers as well, I figured what's another $100.
F-I-T
Blksmok
11-03-2005 08:28:20
PD...you can try some of FIT's recommendations, but what you're seeing are usually signs of a "tired diesel". If you tear it down you will find worn cylinders and worn or broken rings. Most of these diesels got worked pretty hard and have already been rebuilt once (maybe twice) and you will find +.045 or +.090 pistons in the bores.
Mike M
11-03-2005 09:47:06
 Re: 720 diesel oil out of exhaust in reply to Blksmok, 11-03-2005 08:28:20
My cousin bought one a long time ago that was using alot of oil. Finally tore into it and found it bored to .125 but it must of had standard oil rings in it as the bores weren't worn "surprize" and the oil rings had a huge end gap !
F-I-T
11-03-2005 08:12:02
My experience is that you have two possible scenarios. One, it is just gummed up and needs some heat and some work time under a full load to get the rings and injectors loose and working.
Two, and the most probable, it has worn components that are allowing engine oil or diesel fuel to pass, unburnt, out the stack. "Slobbering" is a term that is often used to describe this condition, and it can be attributed to worn rings, valve guides, drippy injectors, poor injector timing, low compression, excessive bore clearances, but generally worn rings and drippy injectors.
If you can rig up a way to test the compression, that would give you some insight. Also, if you are familiar with the injectors, you can dismount them and re-attach them to their tubes while aimed out in to the air (don't put your fingers in front of them!!!) and note that they are spraying correctly without dripping. Then re-check the pump timing, and try it again.
If you go at it with a systematic approach, you can repair refurb certain units until the problem is manageable, but generally this slobbering can only be resolved by the injection a lot of money in parts and time to overhaul the diesel engine and fuel injection system.
Been-there-done-that-got-t-shirt
Frank
