48 B Differential Removal
Leon W
11-03-2005 05:30:44
I am needing to replace a SIDE GEAR and PINION in the differential on a 48B. The manual I have is very tattered and missing some critical pages. The tractor has a powertrol and PTO. I know I have to split the rear axle housing from the transmission but can I leave the powertrol and PTO attached? From the exploded view of the assembly in the manual, it appears there is a coupling on the PTO shaft in the transmission where it would seperate. Also is this gear something I should get from a salvage yard? I have not checked with JD to see if it is available. I appreciate any feed-back.
F-I-T
11-03-2005 17:27:52
 Re: 48 B Differential Removal in reply to Leon W, 11-03-2005 05:30:44
Sure. That coupler will need to be turned as you slide it back together, but that's as easy as having a helper turn the pto shaft while you roll it forward.
Salvage is probably the best way to find a gear. They made so many "B"s it whould be an easy find.
Watch how you block it up! It will be top heavy, so use timbers where they matter, or weld up some putriggers to attach to the frame. Better yet, borrow a nice engine hoist.
Frank
Leon W
11-04-2005 04:52:45
 Re: 48 B Differential Removal in reply to F-I-T, 11-03-2005 17:27:52
I want to thank everyone for the input, and especially for the safety tips. I am planning on tackling this project over the weekend.
Mike M
11-03-2005 07:33:27
I see no problem with leaving the stuff on the back,just make sure it is supported safely so it doesn't flop over on you.Both the front half and the back. If you could even get a new one from Deere I doubt you would want to spend that much ? Should be plenty of complete diff. assy. around salvage yards for those.
Mike M
11-03-2005 07:33:21
Mike M
11-03-2005 07:33:14
