720 crankshaft thrust
nmi720
11-03-2005 04:24:19
Hello all. I am rebuilding my 720 diesel and have a question regarding the crankshaft thrust. I installed the flywheel all the way tight to the thrust washer when i realized i forgot the drive pin. I pulled the flywheel out, installed the pin in the flywheel and lined it up with the slot in the thrust washer. I then reinstalled the flywheel and sent the end play at .006(book says .005-.010). I then relaized there is now a gap between the inside of the flywheel and the thrust. Did i do something worng or is this the correct procedure?
Blksmok
11-03-2005 05:53:26
 Re: 720 crankshaft thrust in reply to nmi720, 11-03-2005 04:24:19
NMI...the end play is actually determined by the distance between the inside of the thrust cover and the leading edge of the spacer. The end play is adjusted by adding or removing shims/gaskets between the thrust cover and the main casing. Most common problem is that the face of the spacer that rides against the thrust plate wears and you can't remove enough shims to get the proper end play. However, it sounds like in your case you didn't run the flywheel all the way into the spacer (purpose of big pressed steel nut) so that the pin was fully seated into the slot in the spacer and the back of the flywheel was tight with the edge of the spacer. Make sure you push and block the crankshaft all the way to the flywheel side when you make the adjustments.
NMI720
11-03-2005 07:13:14
 Re: 720 crankshaft thrust in reply to Blksmok, 11-03-2005 05:53:26
THNAKS GUYS. I DO HAVE A TORQUE WRENCH, DIAL INDICATOR, AND PARTS AND SERVICE MANUAL...I WAS JUST DOUBLE CHECKING MYSELF...I WANT TO DO IT RIGHT. I WILL GO PULL THE FLYWHEEL OFF AND MAKE SURE THERE ISNT ANY JUNK IN THE HOLE IN THE FLYWHEEL
F-I-T
11-03-2005 06:06:32
BlkSmok has explained the mechanism very nicely! Now one 720's there is an another thrust washer inside of the left main bearing....but never having had a -20 diesel apart that far I can't say what affect it might have, but it's in the book and looks to control the thrust against the crank moving to the left.
One hint I'd like to add is that I made a spacer out of pipe, large enough to go over the crankshaft, and long enough to simulate the flywheel thickness. Then you can snug things up using the "tin" nut, and measure your endplay without having to remount the flywheel.
One other thing that I'm sure you don't want to hear, but as a two-cylinder diesel owner you need to know: If you don't have a service manual and you're trying to work around the flywheel, crankshaft, thrust cover, etc., you have a good chance of ending up with a parts tractor in a short time. Even the I&I book for $20 covers the endplay discussion pretty thoroughly, and you need to understand what affects what before you turn it loose and say it's all right. Have a proper torque wrench one hand. No pipe cheaters! And it sounds like you have a dial indicator.....you'd be surprised at how many people complain that they hate the diesels because they had problems with them, and iut turns out they never used an indicator or a torque wrench.
Frank
Mike M
11-03-2005 05:08:22
Sounds like something still isn't right. Could be as simple as a burr on the pin or hole ? I've also had several of those tractors with mixed matched parts in them do to the several design changes done to them. It took alot of careful study with the parts book at hand to get all the proper parts matched up for the right tractor. I would triple check that everything you have is to be in there and something you don't have isn't missing.
