3010 Diesel valve lash. Hot or Cold?
Randalp
11-02-2005 20:42:41
Hi Gents
My manual doesn"t specify hot or cold for valve lash. It only says .018" for intake and exhaust.
What would Deere recommend?
Thanks in advance
Randal
msb
11-03-2005 20:42:40
 Re: 3010 Diesel valve lash. Hot or Cold? in reply to Randalp , 11-02-2005 20:42:41
I am with Kent on this one if no overhaul is involved,but the repair manual says to run the engine for 30 minutes and then readjust the valves after retorqueing the head bolts on an overhaul.I always ,without fail,retorque head bolts.Never had a 10 or 20 series slobber down the side of the block 6 months later when I did this.
Mike M
11-03-2005 09:55:58
Well we still don't have an answer yet ? It may not make too much difference as on the 2cyl. tractors with real long push rods it only varies .002" Maybe set them cold and then recheck hot and see how much it changes ? On the few "newer" tractors I have done I think I did them cold. At school we did one while running once,that was wierd.
4010, ask WTW or other JD
11-03-2005 09:14:48
I was told to make this adjustment cold.
ET
11-03-2005 04:28:18
I belive that is a hot ajustment.
Kent Petersen
11-03-2005 19:38:47
 Re: 3010 Diesel valve lash. Hot or Cold? in reply to ET, 11-03-2005 04:28:18
i have been aJD mach for 40 years set it cold and leave be
