Hey JDGnut, or G-Man
DP
11-02-2005 19:25:35
Quick question. On a 9520, how much oil volume can be pushed through the motor return line and case drain without going to bigger couplers? We redirected some of the return oil and corrected the problem for now, but want it right.
G/MAN
11-03-2005 09:17:49
 Re: Hey JDGnut, or G-Man in reply to DP, 11-02-2005 19:25:35
I don't know about that one, DP. I'm not at work and don't have access to any specs, if there are any. How many motors are you running with it? I think most of our 16-row planters with two motors drain back through the regular couplers with no problems.
DP
11-03-2005 10:04:23
 Re: Hey JDGnut, or G-Man in reply to G/MAN, 11-03-2005 09:17:49
We have one running a SDX40 Air Seeder with the 3380 380 bushel cart. They are pulling the cart behind there 16 shank Blue Jet anhydrous applicator putting down phosprous and zinc with it, and pulling the anhydrous tank behind the air cart. Kept blowing out the fan motor seal. Found that there was too much back pressure. We split up the return lines up with more going to case drain which seems to be working better. Our tractors have a bigger return coupler than the 9520 has. The cart has a 3/4 return line on it, and the tractor has a 1/2 inch coupler.
