2520 Carb Problem
pado2520
11-02-2005 18:21:47
When attempting to start the tractor the carb overloads with gas. Will flood out the spark plugs. If I remove the hose to the air cleaner gas will run out. What is the best way to fix this problem.
Glen in TX
11-02-2005 21:14:47
 Re: 2520 Carb Problem in reply to pado2520, 11-02-2005 18:21:47
Check your fuel system for debri in the fuel that can plug the needle seat in carb. Debri has probably made the carb fuel inlet needle stick open or you could also have a bad fuel laden float. Take it apart to find out and shake float to see if it has fuel inside or hold with pliers in a pan of warm water watching for air bubbles where the float leaks. Get a kit with needle seat and gaskets and float if needed along with a thorough cleaning by soaking and using numbered drills and wires cleaning out passage ways.
