AR Wiring Diagram
Mark Johnson
11-02-2005 10:08:47
I have a John Deere AR and need to rewire the tractor. Does anyone have a recommendation for a shop book or some place to get a a diagram?
Thanks for the help!
El Toro
11-02-2005 17:19:30
 Re: AR Wiring Diagram in reply to Mark Johnson, 11-02-2005 10:08:47
Here's a web site for wiring harness' You could redo that wiring yourself by removing one wire at a time and replacing it. Use a good grade of copper wire and solder the lugs or terminals. Hal
PS: They aren't cheap.
http://www.wiringharnesses.com/
Glen in TX
11-02-2005 13:06:23
The AR unstyled or styled isn't in the JD SM2029 Electrical manual. It would be basically the same for the A & others just different locations somewhat. Parts book only shows a intact wiring harness. I would like to find a good diagram for the styled AR also.
