BR clutch
J Bouchard
11-01-2005 18:42:23
No matter how I adjust the clutch, I can not get a good 'snap" when I engage the clutch. I have cleaned out the parts and reassembled without any improvement. Which parts should I look to replace? The T bolts? The cast pieces? or the pins that fit in the cast pieces? Don't say all of them, this is all obsolete parts,according to Ma Deere.
Kent Petersen
11-05-2005 05:17:57
 Re: BR clutch in reply to J Bouchard, 11-01-2005 18:42:23
see my post on page 3 under 41 b clutch Kent
Mike M
11-02-2005 05:20:37
Have you had the entire pulley assy. off and cleaned it up yet ? Clean up and relube the toggles and dogs and check the pin and it's hole that keeps the operating sleeve from rotating.If these move much it lets the toggles loosen up and you can't seem to hold an adjustment.
J Bouchard
11-02-2005 08:23:56
 Re: BR clutch in reply to Mike M, 11-02-2005 05:20:37
I have taken the entire assembly out ,apart and cleaned with no change. I did not check this pin you refer to but it does stay adjusted it just doesn,t snap to engage.
ET
11-02-2005 04:52:52
The cast pieces or toggles are probably worn.
J Bouchard
11-02-2005 08:26:23
 Re: BR clutch in reply to ET, 11-02-2005 04:52:52
Any idea of where I could look to purchase replacements, since they are not in the JD system?
ET
11-02-2005 09:28:03
 Re: BR clutch in reply to J Bouchard, 11-02-2005 08:26:23
The toggles might be the same as on a row crop B so good used ones may not be hard to find.
