41 John Deere B clutch kicking out
Justin S
11-01-2005 15:46:14
Im having trouble with my 41 b clutch actually stopping while engaged and if i disengage it then reengage it it'll work fine. if anyone might know whats wrong or needs other info on this than ill describe it more. thank you!!!!
Kent Petersen
11-01-2005 16:24:19
 Re: 41 John Deere B clutch kicking out in reply to Justin S, 11-01-2005 15:46:14
uoy will haft to remove pulley and check the pin and hole in toggle operating hub this is the part that the fork fits in if the pin or hole or both are worn the hub will rotate out of alinement with the toggles this releases the clutch Good Luck Kent
