3020 Wiring Harness
kdagenais
11-01-2005 09:41:25
Hello,
Just wondering if anyone new if the wiring harness for a 3020 is still available from John Deere? If so I would like the part number for a 3020 gas single 12volt battery tractor if possible. Thanks In advance,
G/MAN
11-01-2005 13:34:46
 Re: 3020 Wiring Harness in reply to kdagenais, 11-01-2005 09:41:25
There are several wiring harnesses on those tractors, all connected together. Most of those harnesses are still available. I did some extensive rewiring on a 3020 or 3010 a while back. I can't remember which for sure, but I was able to get everything. However, some of the harnesses subbed, and you may end up changing around some connectors and/or replacing more than one section in order to connect. For instance, the harnesses for the fenders plug into another larger harness that leads from the switches and breakers back under the platform, etc. It all becomes more clear when you look at a parts diagram. There might also be differences between the early and late tractors, too. Have serial number in hand when ordering.
