2010 Engine Swap
TDK
11-01-2005 06:17:15
Never really got an answer before, so I'm asking again. Have any of you done a swap on a 2010 gas engine? I would rather it be a bolt in job if possible. Not going to swap to diesel, or another brand of gas. Owner just wants to do this as easily as possible and not break the bank. Appreciate any and all info. You're welcome to send me an email if you want. Thanks!
TDK
11-02-2005 20:15:53
 Re: 2010 Engine Swap in reply to TDK, 11-01-2005 06:17:15
Thanks HTR. I was hoping to find something that would easily swap. I have a complete engine from the tractor, but it's not worth fixing. Tractor is not mine and owner is hoping to do this as economically as possible.
HTR
11-02-2005 19:25:21
A 145 engine from a 45 combine is pretty much a bolt in. The exhaust manifold is different. The Governor linkage is different, and I think you have to use the water pump from the 2010. Maybe some other small problems, but not much.
The HA145 and HB145 were parent bore engines, and the HC145 and later were sleeve and deck engines. Either will bolt in.
