Another JD 1530 Question
John in Oh
11-01-2005 02:23:45
Can the hydraulic screen and hydraulic filter on a JD 1530 be removed, without drainng the system? I am trying to figure out why the hydraulics won't lift 300lbs. I would think it should lift 1500lbs or more.
MSM
11-01-2005 15:55:27
 Re: Another JD 1530 Question in reply to John in Oh, 11-01-2005 02:23:45
In your other post,you said the loader lifted fine.That would leave out a clogged filter or screen. You have a problem in the rockshaft housing,leaking valve,bad piston seals,split cylinder,or other internal leak.
John inOH
11-02-2005 02:15:12
 Re: Another JD 1530 Question in reply to MSM, 11-01-2005 15:55:27
It lifts slowly with no weigh on it, but will not lift at all with 300lb blade
Tx Jim
11-01-2005 04:09:13
John,the filter can be changed w/o draining but the screen can't. I would change and if it still won't lift correctly check stand-by pressure(2250 psi). The pressure control valve down by hyd.filter could be stuck! Tx Jim
John in OH
11-01-2005 07:04:12
 Re: Another JD 1530 Question in reply to Tx Jim, 11-01-2005 04:09:13
How much to I need to drain to pull the screen?
Thanks
John
Mike M
11-01-2005 09:10:44
 Re: Another JD 1530 Question in reply to John in OH, 11-01-2005 07:04:12
All of it.
