Gentlemen, last night I posted a question asking how to identify a "new" JD I just acquired. Have never owned a JD before. You all responded very quickly and kindly to my inquire and I can safely say I now have the bragging rights to a 1941 or 42 "B". Serial number B-101970.Brought it home late today. Since it had been sitting in tall grass for a number of years I was anxious to see if the engine was not frozen (stuck), so got my jumper cables. Before cranking it, I decided to put some gas in the tank, opened the little wing nut underneath the carb. and watched water, rust, and dirt pour out of it for awhile. Afterwards closed the wing nut, got my jumper cables and made contact with the positive part of the starter. After three trys, the darn thing started choking and coughing and gagging, AND THEN IT STARTED UP. Oh how sweet the sound! Quickly got on and put it in gear, forward than back. Worked ok. Did not let it run for long, about 30 seconds or so, because both 2 inches pipes or hoses going to and from the radiator are rusted and torn with rust and gunck in them, so there is no water in the engine or radiator. The top part of the radiator, where the pressure cap goes, is all rusted out and gone, there is 4 to 5 inch gap. So I guess tomorrow I will try to "flush" the radiator system and see if I can get some water to the engine before firing her up again. So, all this means that since I am a newbie I may be bothering some of you all again for advice. Will go searching for manual at TSC. Thanks again, you guys are great. Davidz
