Can't get my G started????
davebr
10-31-2005 16:58:58
Hey Guys, I need some help. I have a 1950 GW electric start. I cleaned the plugs, Changed the inline fuel filter, put gas in the tank. She turns over very hard and slow even with the charger starter in start mode. Running one twelve volt battery. It has an alternator on it that doesn't charge. I get it to pop every now and then but not enough to get it going. Could it be the points? It has a mag on it. I ought to just sell this thing and be done with it but it is too nice a tractor. Do G's usually turn over this hard?
Any help would be appreciated.
Dave
JLG
11-01-2005 17:31:45
 Re: Can't get my G started???? in reply to davebr, 10-31-2005 16:58:58
My '50 G wouldn't start a few weeks ago. I checked the timing, point gap, carb. Finally put in brand new spark plugs, AC c87's, and it fired on the third turn of the flywheel. I thought I was getting a pretty good spark out of the old ones, guess it just wasnt good enough! My great uncle has a Minnie-MO engine on a sawmill. He says he changes those plugs once a year too or it gets hard to start. You could give it a shot, they're only $3.
DW
11-01-2005 06:19:20
I have my "G" .125 over with Hinrich pistons, and it cranks hard. I always open the petcocks. One thing I have to watch very close, is flooding. I always turn it over before choking, if it doesn't fire I choke it but not longer than one revolution of the crankshaft or it will flood. When it floods, it is hopeless and sometimes needs to be pulled. Hope this helps.
Davebr
10-31-2005 20:12:28
 Thanks Guys in reply to davebr, 10-31-2005 16:58:58
I really appreciate it.
Dave
John T
10-31-2005 19:36:21
Dave, Especially on a Magneto Ignition YES it could be the points. Make sure they are clean n gapped proper and if they are gray oxide coated run a dollar bill or a shop cloth between them to non abrasively clean/buff/polish them n see what happens. However, if they are badly burned or pitted or carboned up REPLACE THEM.
Since it has a mag, that slow cranking shouldnt cause a weaker spark (as it can on a coil ignition) but if the mags spring is weak, that can cause a real weak starting spark. If you can pull start her n she fires right up n runs good, you may wanna suspect a weak mag spring. Does it make a loud sharp SNAP (good spring) or a faint dull clunk (weak spring)???
Remove a plug n have its wire atached but its side grounded n turn her over and insure a good visible blue spark and NOT a faint thin wimnpy yellow spark!! If so the ignition needs some attention like points or condensor or coil or plugs or even plug wires or a weak spring etc. On a mag you need to use good wire core wires as opposed to the carbon core suppressor types !!
Have you tried new plugs??? on those mag ignitions, a dirty or partly fouled or oiled or gassed up plug can wreak havoc on starting.
Hows the compression??? If its low, try removing the plugs n squirt some oil in the cylinders n see of she starts better then???
Do you have fresh clean water free gas and is she getting plenty gas when cranking?? If it is the plugs ought to be a lil wet and/or you get some gas vapor out the open petcocks and a lil black smoke out the stack when cranking. If the plugs come out bone dry and theres no black smoke out the stack nor vapor out the petcocks you better take a look at the carb and fuel supply and insure the choke butterfly plate is actually closing tight???
Slow cranking can be a weak or undersized battery or a bad starter switch or even a bad starter. To be safe, remove n clean n wire brush each n every battery n starter n ground cable and use 0 Gauge cables and the biggest n highest rated CCA battery that will fit in the box. Maybe have the battery load tested at a shop !!! it may be weak. If the batterY is grounded to any rusty tin seat or battery box, it helps if you ground it to a good main frame bolts as close to the starter as possible, TRY THAT.
If the lights dim way down badly when cranking I suspect the starter motor more, but if they dont dim much n she slow cranks, I suspect a bad starter switch or bad cables or a poor connection or ground somewhere.
Check the points n the spark quality and see how loud n sharp the mag snaps and wheres your start timing set??? Try a pull start n see how she does??
NO, a G shouldnt crank that hard if you have a good heavy duty battery, good cables n connections n grounds, and a good starter switch n starter !!!!! !!!!!
To start a G you need a good strong blue spark, good plugs n wires, good compression n fresh clean gas.
John T
Daniel Chestnut
10-31-2005 17:27:28
I have a big 12 volt battery out of an ambulance in my G. Its bored 90 over with M&W pistons and it starts it with both petcocks open or closed. When I had a small battery in it, I had to open the petcocks to start it. I"d put a bigger battery in it for starters.
