520LP falls flat on it's face under heavy load??
tyler-mo
10-31-2005 13:20:22
Hello,
At a recent plow day, I discovered that my 520LP tractor would pull pretty well with 2-14" in black river gumbo. The only problem was that under heavy pull 3rd gear and when it would drop below about 1000 rpms it would most often just fall flat on it"s face with not even being able to keep it from dying be disengaging the clutch. I"ve completely gone throught the tractor, including a new LP convertor and ignition. Any ideas to what could be causing this problem. It points to condensor by all means, but it will run all day long at max idle with only running down the road....it only does this under heavy load. Please share any and all thoughts....it looks kinda bad when your just truckin" along and all of the sudden dead!!
Thanks,
Tyler in Missouri
730-LP
11-02-2005 17:34:43
 Re: 520LP falls flat on it's face under heavy load in reply to tyler-mo, 10-31-2005 13:20:22
Tyler have you checked the breather LP's are really pickey when it comes to air they will not run with out the breather cup.and will not run right if the oil level and weight in the cup is not right.
Mike M
11-01-2005 05:34:47
Nobody mentioned it yet ? Are you starting on vapor and then when warmed up opening the liquid and then closing the vapor valves ? I think you are only to run on liquid to get full power.Is your converter getting warm coolant through it so it doesn't frost up ?
tyler-mo
11-01-2005 10:33:30
 Re: 520LP falls flat on it's face under heavy load in reply to Mike M, 11-01-2005 05:34:47
My convertor doesn't frost up and is getting warm. I switch to liquid after closing the vapor valve. I might check out the excess flow idea out. I would think that when under full pull it should let more LP through the carb because the governor should let her open up wide open when RPM's drop...that makes sense. It's easy enough to test. I haven't tested to see if this problem happens only on liquid...maybe if it doesn't do it on vapor?? I don't know.
My wiring harness is new along with all ignition parts (coil, spark plugs (I'll check them just in case). Thanks for all of the ideas.....
I'll report back here when i figure it out.
Thanks,
Tyler in Missouri
Ben.So.Tex
11-01-2005 04:16:53
My 720LP was doing about the same thing and I had one of the spark plug gap Way to wide. When I got my 730LP I had to open the load neddle up on the carb, It located laying flat between the barrel of the carb, Both run great now. Who help me with this, Was Tom from MO. here on the site. Check the archives for some help there. Later Ben
Pappy
10-31-2005 23:01:02
For some reason, you are not burning enough fuel for the heavy load. Start checking to see why.
Glen in TX
10-31-2005 21:49:59
Tyler, I had something like that going on with a 520 LP but won't know if I found it all until I get more clutch parts. Most of mine may have been wiring problems. Just have to narrow it down. What shape is your wiring harness in? When wires heat and expand a bad spot opens up but makes connection when cool again. You could still have carb or fuel problems? You said new converter and ignition. How much new ignition? You mentioned condenser so try the old condenser. Does it start right back up and have fire or have to cool off some? Could be the coil and or condenser. Plug wires? Has the air cleaner been cleaned out? Mud dobber nests? Oil cup needs to on and level right when setting a LP carb. Wear in governor linkage and parts? Governor parts have given me fits on other LP JDs before. The LP excess flow valve disc can shut if you open the valve fast and stop flow. That is what they are designed to do in case a line blows. It isn't going to shut for a small leak unless defective. Take a line loose and CAREFULY let some blow out when cool to test flow. Seldom see those give trouble and usually find other problems. Happy hunting.
lonzo
10-31-2005 19:52:54
did you try opening the fuel adjustment on the carbrator, the air cleaner can cause fits. does the tractor do this trick righ off or does it take a bit of time?
Johnbob
10-31-2005 16:32:13
Sound like it may be the safty valve on the back of the outlet valve.The bad part is it is inside the tank.It shuts the gas off if a hose breaks or too much gas is going out.
CLW
10-31-2005 19:17:44
 Re: 520LP falls flat on it's face under heavy load in reply to Johnbob, 10-31-2005 16:32:13
Johnbob it could be that but if it were I would think it would happen at anytime, not just under a HEAVY load.
CLW
