Drop in Oil pressure-JD-49B
courtland
10-31-2005 06:08:03
My 49 B seems to have had a drop in oil pressure. It has gone from consistanly at MEDIUM pressure to a bit lower at idle. It will rise at higher RPM's.
Should I be concerned?
DickD
10-31-2005 20:25:47
 Re: Drop in Oil pressure-JD-49B in reply to courtland , 10-31-2005 06:08:03
There can be several contributing factors to different oil pressure readings. Here are a few of the easy ones. Have you used a different oil, or a different viscosity oil? Even a different kind of filter can make a difference in pressure readings. Remember, these engines have quite a bit of bearing tolerance, so it is important to use the recomended oil. Is the guage working properly. Just a few things to check out before surgury.
courtland
11-01-2005 05:44:48
 Re: Drop in Oil pressure-JD-49B in reply to DickD , 10-31-2005 20:25:47
I have not made any changes, I always use the same oil and filter brands. Visually things look ok in terms of leaks etc.
This tractor gets very little use, which has caused me to be even more curious. I will keep an eye on it. How LOW is too low for oil pressure??
