JD 1530 won't lift 300lb blade
John in OH
10-31-2005 03:04:40
My John Deere 1530 won't lift a 300lb 7 FT blade. It will lift with no weight on it. The JD145 loader runs off the same hydraulic system and works fine. Any suggestions would be appreciated.
Thanks
John
splitinheadache
11-03-2005 17:18:23
 Re: JD 1530 won't lift 300lb blade in reply to John in OH, 10-31-2005 03:04:40
my new logspliter wont split have changed filter cleaned 2 screens replaced pressure relief vavle and tried 2 flush milky fluid but still a bit milky. used 5 gallons jd fluid and 5 gallons off brand. any comments on that about to give this logkisser back to tractor supply and sharpin my mual JD 1530
Charlie1520
10-31-2005 06:08:12
Hi, I have a JD1530 and a rear blade. Its only a 6ft blade but I don't have any problem lifting it. Could it have anything to do with your draft control setting? I know that having it one way makes the blade lift operate weird. I can't remember which setting works best but I could check this evening if you don't get any other messages on this. Hope this helps.
