Identifying JD tractor
davidz
10-30-2005 21:23:52
Just aquired an old rusty looking John Deere tractor from a relative I had not seen for sometime.
He is not sure, but he thinks it might be a "B" from the 40s or 50s.
Where or what do I look for to find the model and serial number. I know that the Ford forum (bite my tongue) has an area which shows where to find the serial number, with a list of models for the various years. Is there something similar for JDs??
Any help will be greatly appreciated. Davidz
HoboBob
10-31-2005 14:19:27
 Re: Identifying JD tractor in reply to davidz, 10-30-2005 21:23:52
If it is styled, it it sould have 7 slots in the front grill, intake and exaust are in a strait line, its a B.
If the front grill has 8 slots and the intake and exaust are in a line its an A
if the front has 8 slots, and intake/exaust is opposed, its a G.
You will need the serial number to deturmine year. Just use the info that has allready been givn to you. Hope this helps. HoboBob
Maark
10-31-2005 10:54:33
On a styled model look on the right side below the mag or dist.above the clutch, there should be a serial# plate located there. Or the holes that used to hold the plate on.If it is an unstyled model the ser# will be located just ahead of the flywheel.at about 11 0'clock position.
Joe MD
10-31-2005 10:24:13
If you can't find the serial then it is probably gone. Kind of hard to miss.
If any of the big casting parts have a B in front of the part number then it is a B. Look on the back by the PTO.
CLW
10-30-2005 22:21:39
If you are not sure, or can't find your serial number on that page post it and we can tell you what it is. Serial number should be on the pully side. (right side as you sit on it) Will be on the top of the main case near the mag. If it is a B it will say something like "Model B 191303". If it don't have a tag you will have to discribe the tractor to get help.
CLW
CLW
10-30-2005 22:09:30
On the left of this page under "Research & Info" you can click on "Serial Numbers". CLW
