3010 shifting
BradB
10-30-2005 16:21:31
Would like to get my 3010D syncro to shift a little easier. I have already worked on the shifter linkage and now need to go into the tranny.I have the IT manual and will read it a couple more times before starting. Have read about worn shifting forks and shafts. Is this going to be a job for JD shop? or is it something I could do by the manual? Mainly bothers in 4th and 2nd. Very hard to get into 4th. Love this tractor but just need to get it shifting better. As always thanks for the advise.
lonzo
10-31-2005 20:00:18
 Re: 3010 shifting in reply to BradB, 10-30-2005 16:21:31
take the detent pistons out and grinde a groove down the sides so that the oil that gets trapped behind the piston can escape and let the detent move, it's like a hydraulic lock when the oil get behind the piston
msb
10-30-2005 18:50:05
Before you pop the top of the transmission,it might be a good idea to unhook the linkage at the shiter levers on the side of the transmission and see it the shift quadrant in the dash is not part of the problem.The next place to check are the detents.Remove them and see it that eliminates the trouble.You can substitute the ball and cups used on the 2010 models to solve sticking detent problems on 3010 and 4010 tractors.
BradB
10-31-2005 13:17:27
 Re: 3010 shifting in reply to msb, 10-30-2005 18:50:05
Worked on the shift quadrant last winter. Replaced the bushings and a yoke and the roll pins. I will try unhooking the linkage and see. Where are the detents? Have not looked at the manual yet.
msb
10-31-2005 19:04:57
 Re: 3010 shifting in reply to BradB, 10-31-2005 13:17:27
Detents are on the right side of the transmission near thge shift arms.Think they take a 1 1/8" wrench.Plug with washer or spacer shims,spring and detent.
