How wide a disk for a 1955 50?
Chuck McDonald
10-30-2005 06:18:17
Hey,
I am in the market for a disk again and was wondering exactly how wide a disk I can pull. Obviously, it could be set more shallow if condidtions got bad.
Would I be able to handle an 8' if it was not digging to the axle on the disk? I plan on having bigger tractors in the future, but for now my 50 is the most powerfull one I have.
Thanks
Chuck
G/MAN
11-01-2005 13:37:06
 Re: How wide a disk for a 1955 50? in reply to Chuck McDonald, 10-30-2005 06:18:17
I agree with Mike. A disk doesn't do much good if you can only pull it deep enough that a field cultivator would do the same job. A smaller one you can pull anywhere at the depth you want will do a better job than a big one you have to raise to pull.
PJBrown
10-30-2005 17:02:18
We pull a 8' KBA with our 50. I wouldn't go much wider.
ChuckW
10-30-2005 15:39:31
I have a 5' landpride like new for sale on ebay. It is a lift 3 point.
Mike Aylward
10-30-2005 10:56:27
Chuck, I would vote for an eight foot disk over anything much bigger. Sure, you can raise up the disk, but do you want to "scratch" numerous times? An eight footer will allow you to raise the wheels on the disk and still be able to horse it even in plowed ground. And you can move up to fourth gear in favorable conditions. If you go much bigger you will be looking at third all the time with the possibility of losing traction in lose ground. You will get the job done just as fast with an eight footer and with something larger and the disk and tractor will be a much more balanced unit. If you get a bigger tractor later you will just run at the fourth gear-equivalent speed that your 50 has now. I live in northeast Missouri and we used to run a '51 B on an eight foot RW disk and it handled it fine, although the tractor was "enhanced". Our '49 A handled it very well and would also handle a nine foot and also an eleven foot RW but you would do it easier on less fuel with the eight footer and get done just about as fast. Hope this helps. Mike
55 50
10-30-2005 10:10:23
I have a 10 ft for my 50. If you buy a hydraulic lift type, then you can adjust depth as needed. So 8 ft or 10 ft are OK if they are depth adjustable.
