Hydraulic supply tee? 4020
Nylon
10-29-2005 22:15:38
I have my valve mounted for a joystick. The working ports are 1/2 inch. The supply and return lines are 3/4 inch. The line supplying the rockshat by the brakes is 1/2 inch. There would be no point in running 3/4 line and t to a 1/2 inch supply would there? I may as well make the supply and return lines 1/2 inch unless you guys have a reason that I would need 3/4. I was planning to use a 3/4 to 1/2 inch fitting adaptor at the valve inlet and outlet for 1/2 inch line.
Thanks for input,
John
Boog
11-01-2005 04:58:05
 Re: Hydraulic supply tee? 4020 in reply to Nylon, 10-29-2005 22:15:38
If your return is a true return and never used as a supply, it should be slightly larger than the supply side line. If you make them the same size, things will work OK most of the time but system performance will not be optimized: actuators will not operate as fast (the heavier the load the greater the slowdown); flow into the resevoir will be faster and create more foaming (foaming creates several problems I will not list here); also because of this faster flow, temperatures will be slightly higher breaking down the fluid faster as well as the soft goods in the system.
Mike M
10-30-2005 17:48:18
I bet 1/2" will be fine as the hole in that fitting is maybe 3/8" where it hooks to.
Glen Anderson
10-30-2005 10:28:32
I've used 1/2" lines for both pressure and return on several of our tractors with no problems.
J. Schwiebert
10-30-2005 05:15:14
Just remember one thing. You always return more oil from a cylinder than you put in it when the cylinder retracts. Also there are tables for line size and oil flow so you have the right speed for the GPM you are working with.
Nylon
10-30-2005 15:54:34
 Re: Hydraulic supply tee? 4020 in reply to J. Schwiebert, 10-30-2005 05:15:14
That is good to know about the retract. That is one line that can easily remain at 3/4 all the way out of the valve through the fittings and into the return T. The supply side is going to be 1/2 inch. Thanks for the info guys,
John
