Fan belt change 4020 Bushings on coupler?
Nylon
10-29-2005 22:05:03
Hey guys,
I am going to change out the fan belt and add the spacer bushing I found wedged in the frame to the alternator. I remember someone mentioning that there was nylon something or other that should be replaced in the hydro pump shaft coupler. I am trying to put together a complete list of items for my jd parts order. This is for my minnie overhaul / spruce up.
Thanks,
John
Glen Anderson
10-30-2005 10:23:39
 Re: Fan belt change 4020 Bushings on coupler? in reply to Nylon, 10-29-2005 22:05:03
I just replaced the bushings on both our 4020 and 3020. There are 2 bushings on the engine portion of the coupler and 2 bushings on the hyd. pump portion of the coupler. Make sure when you change the bushings that you inspect the condition of the splines on the coupler that engages the hyd. pump shaft, if they are questionable at all, replace that portion of the coupler as well.
