Hydraulic Oil Temp. III
Larry48
10-29-2005 19:29:38
You guys were exactly right, I replaced the open center valve on my log splitter with a closed center valve and my cylinder is "cool as a cucumber"!!! Its amazing how my old jonny popper responded...with the closed center valve, whenever you aren't moving the control lever, you can hear the engine lose RPM's, and as soon as you move it, you can hear the govenor kick in and hear it idle up.... I think what just flabberbasts me most is how little time it takes for the hydraulic system to sense changes in pressure. I really had no idea it could happen that fast. I ran it for a couple of hours splitting some wood I had already cut up and it never hardly got hot. (I had intendend to use my infared heat sensor to see what the temp was but I forgot to bring it) At any rate, I want to say THANKS to you all who gave me advice on what to do, it turned out perfectly.....Thanks again
Mike M
10-30-2005 17:52:44
 Re: Hydraulic Oil Temp. III in reply to Larry48, 10-29-2005 19:29:38
Only one problem left. Johnny Poppers don't have closed center hydraulics ? You must have a New Generation tractor.
