3010 battery shut off switch
cahoot
10-29-2005 10:56:23
I've had problems with my batteries dieing so I bought new batteries and a night switch(main battery shut off). I pulled the floor plate off and was wondering where I should be cutting the switch in. The positive going to the starter or the positive going to ground, or maybe neither. I'd rather not kill my new batteries first time I hook them up. Thanks for any tips!!
MSM
10-29-2005 11:28:20
 Re: 3010 battery shut off switch in reply to cahoot, 10-29-2005 10:56:23
If it is a diesel you will need 2 switches,one for each battery,due to the way it is factory wired,(24V start and charge,but 12V for lites and accessories).If the tractor does have a draw,it would be better to track it down(regulator sticking,generator or starter with an internal short are common.If you put the cut off on one battery,there is a good possibility the other battery will still go dead.
