J.D. 720 Three Point Hitch problem.
Doug A.
11-08-1999 18:23:37
On my 720 diesel 3-pt hitch will raise but only lowers about a fourth of the way.Remotes work fine.Acts like a valve is stuck somewhere.Any suggestions appreciated. Thanks,Doug A.
Steve
11-08-1999 18:56:09
 Re: J.D. 720 Three Point Hitch problem. in reply to Doug A., 11-08-1999 18:23:37
Is this with or without a load?
Doug A.
11-09-1999 05:55:00
 Re: Re: J.D. 720 Three Point Hitch problem. in reply to Steve, 11-08-1999 18:56:09
Can not get it down low enough to hook up plow.Dont know what will happen with load.
Steve Edwards
11-09-1999 14:02:24
 Re: Re: Re: J.D. 720 Three Point Hitch problem. in reply to Doug A., 11-09-1999 05:55:00
My 520 has a return spring on the left side arm up near the rockshaft to drop the arms to the lower position. It is a very stout spring. I assume you have tried pushing the arms down manually with the lever all the way forward. If this didn't work you have a mechanical problem in either the valve or the rockshaft cyl. You'll need to take it apart to fix.
