318 dies for no reason-electrical-new symptoms
HfJeff
10-29-2005 07:12:13
We (pa and I) still do not have this problem resolved. But before the problem came and went. Now it is here to stay. The battery indicator on the dash is on. Tractor runs perfectly in neutral. When I turn on the PTO, it dies. When I move it out of neutral, it dies. I can hold my finger on the neutral safety switch and drive it around, at least to get it back in the garage. Could this be the "brain box" under the dash? Also with tractor off and key switch on, the electric clutch does not engage when I switch on the PTO. Any ideas? THanks. Jeff.
2cylfarmer
10-31-2005 18:19:54
 Re: 318 dies for no reason-electrical-new symptoms in reply to HfJeff, 10-29-2005 07:12:13
Our mower had similar problems. It turned out to be a bad coil on the electro-magnetic clutch on the front of the engine
Carl NY
10-29-2005 17:59:33
From the symptoms you have stated, I believe your problem is the brain box. This sounds exactly what I experienced with my 318. The box is probably under the battery and tray. Sounds like someone may have jumpered some wires around to make it work and now they are disconected. Go to your Deere dealer and buy a new brain box and make copies of the wiring diagrams. Good luck.
kdagenais
10-29-2005 07:40:05
Sounds like something is wrong with the seat switch. If it has been bypassed that would be my first suspect area to look at. If it is still hooked up I would guess the switch is bad and you can test this theory by unplugging it and place a jumper in the harness on the tractor side. Then if that don't fix your problem you will have to trace the wire from the back to the front for an broken wire.
Good Luck!
HfJeff
10-29-2005 09:26:14
 Re: 318 dies for no reason-electrical-new symptoms in reply to kdagenais, 10-29-2005 07:40:05
This keeps coming back to the seat switch wiring. We did bypass the seat switch. Checked with a dealer and confirmed they should be shorted together on the tractor side. Next my dad found a wire nut lying on top of the mower deck. I may have to trace back the seat switch wiring and make sure the previous owner did not splice somewhere. Are there any other safety switches to check? Thanks.
kdagenais
11-01-2005 09:46:05
 Re: 318 dies for no reason-electrical-new symptoms in reply to HfJeff, 10-29-2005 09:26:14
The only saftey switches I can remember is the neutral & seat switch. Would definetly pull the fender deck of and trace the wire for the seat switch back. Almost positive that this is your problem. If it where the brain box you would have different problems.
Good Luck!
