1948 G battery
Dawg
10-29-2005 06:05:29
What did the "48 G have for batteries? Was it 6 volt or 12? Thanks
F-I-T
10-29-2005 10:54:17
 Re: 1948 G battery in reply to Dawg, 10-29-2005 06:05:29
third party image
Sawg:
If your "G" is S/N 26,000 (under seat battery box) or higher, it was 12 volt from the factory, and it used two 6 volt batteries in series to produce 12 volts. Since 6 volt batteries in that day were pretty light in CCA's, a single 12 volt modern battery in the 900 and up CCA range is often used. But since that engine, even as a low compression all-fuel, the displacement is so great, you'll need to have the best cables and a starter and batteries in good condition to roll it over in cold temperatures.
The "G"s previous to this change were 6 volts, and with a single 6 volt battery, they struggled.
You might want to consider an Optima gel-type battery. They offer a 800 CCA 6 volter, and in series, two of those would crank it for many years to come, with no maintenance, and no acid spills.
Frank
Dawg
10-30-2005 10:55:33
 Re: 1948 G battery in reply to F-I-T, 10-29-2005 10:54:17
Thank you guys for the info and thanks for the diagram Frank.
Bob Collins
10-29-2005 12:08:06
Frank, I think you made a small error in stating the "G" before 26,000 was 6 volt, actually I think they were 12 volt after 13,000 but the "GM" models with electric start used one 12 volt battery in front of the valve cover rather than 2 6 volt batteries under the seat. My "GM" 19xxx has a 12 volt system and it takes a lot to crank it, I can't imagine them starting on 6v unless everything was just right.
F-I-T
10-29-2005 12:46:58
 Re: 1948 G battery in reply to Bob Collins, 10-29-2005 12:08:06
third party image
Bob:
You are correct. The 13,000's and up, before the square seat battery box were 12 volts as well. I was in a hurry, but doesn't excuse it. I sneaked a quick look at the lighting equipment, and erred by looking at the "Lighting only" page, and those used a 6 volt generator.
Here's a picture of the 13,000 and up electrical, which clearly shows the 2-6volt batteries in series arrangement.
Frank
P Browning
10-29-2005 07:52:35
The wiring diagram for G-26000 & up tractors show a pair of 6-volt batteries in series, but with basically a 12-volt system, positive ground. This from SM2029, page 80-5-9. If you would like the wiring diragram, write me & ask for it. (PatB)
John T
10-29-2005 06:15:09
Dawg, Sorry I dont have the answer, HOWEVER if it has no battery now and you wanna even think about it starting in the dead of winter, I would use 12 volt (and convert the tractor if it were 6) and still 0 or even better 00 Gauge Battery n Starter n Ground Cables on a G and the biggest and highest rated CCA battery that will physically fit into the box. On a lot of the 12 volt systems in those early days they used two six volts in series you know, but with todays batteries a single super heavy duty 12 volt ought to start a G just fine. Its a diferent thing if starting a little B or an H in the winter, but for an A but especialy a G, I would want 12 volts fer sure.
John T
