Hydraulic line attachment for snow plow
Dalton
10-29-2005 05:52:00
I"m planning to remove the bucket from the loader this winter and replace it with a plow with hydraulic controls. I don"t have remote outlets so I plan to swap the bucket cylinder hoses for the plow hoses at the control valve. A couple of others I"ve spoken with say this works okay. However they say that after some use the plow angle may change as the bucket cylinders "relax". Anybody here used this approach? Any comments?
Thanks in advance.
Dalton
10-30-2005 03:27:34
 Re: Hydraulic line attachment for snow plow in reply to Dalton, 10-29-2005 05:52:00
MSM, Jonathan, I appreciate your suggestions. I'll explore both!
Thanks again!
Jonathan in MA
10-29-2005 15:31:47
There are lots of different methods of operating a plow. As mentioned you can add a valve section for just the plow...or you can add a diverter valve into the bucket circuit and switch between bucket operation and plow angle. This can be a manually operated valve or I've done some with a solenoid controlled diverter valve with a switch mounted on the loader lever. I'm not sure what kind of tractor it is . If it has a closed center hydraulic system , you can tee a seperate valve into the pressure line...either manually operated or solenoid controlled . There are lots of options depending on how easy you want it to operate but also with greater ease comes greater initial cost.
MSM
10-29-2005 10:24:25
Why not install a 3 spool valve,leave the bucket plumbing intact,this way you have an "auxillary circuit" which could control the angle of the snow plow,or act as a remote by moving the hoses to the rear of the tractor when the blade is removed.Just a thought.
