JD4230 tractor, electrical problem in cab
Mark
11-08-1999 17:51:09
JD4230 w/cab. The overhead console in the cab is not getting any power.the radio, fan blower and wipers are all not working. the light in the headliner does work. the manual says to shut the items off for a minute, then turn the item back on to reset the circuit breaker. This didn't work. It was also suggested to me to disconnect the battery ground for several minutes and reconnect. This too did not work. Are there any fuses (other than to the radio)? Any other suggestions??Please help!!!
ROBERT
11-08-1999 19:23:56
 Re: JD4230 tractor, electrical problem in cab in reply to Mark, 11-08-1999 17:51:09
HAVE YOU REMOVED THE COVER TO THE CIRCIT BREKERS
(THE TIN BETWEN THE STREERING WHEEL AND FRONT OF THE CAB). CHECK THE CAB RELAY,IT WILL CLICK WHIN YOU TURN THE KEY ON.IF IT DOSE THAT TACK A WIRE AND HOLD IT ACROSS THE TWO BIG TREADED POST ON EACH SIDE.THE FAN AND RAD SHOULD WORK. DO NOT REPLACE THE RELAY THAY WILL NOT LAST AND ARE EXPINSIV.GO TO JD HOLD THE PARTS MAN BY HIS COLER UNTILL HIS IS IN THE MOOD TO FIND THE RIGHT PARTS!!!!! !THERE IS AN UP GRADE KIT FOR THAT. IT IS A NEW KIND OF RELAY THAT WIRES IN EZ!!!!! !!!
I DONT HAVE PARTS BOOK AT HOME OR I WOULD LOOK IT UP FOR YOU.IF THAY GIVE YOU ANY LIP GUST E-MAIL ME AND I WILL FIND IT.YOU MAY HAVE TO GO TO ERLY 4240S TO FIND THE KIT. ROBERT
