720D pony and main rods.
DirtJockey
10-28-2005 20:39:27
When I first started my prize 720 diesel the over running clutch for the pony seem like it was slipping, but the engine started and I drove it home. While changing all the fluids I discovered the pony trans was empty. There seems to be no sign of leakage either. after filling the trans it works like normal with no signs of slipping. This has been bothering me so I am going to pull the complete pony and take down the trans. My question - anything in there a mandatory change while I am at it or just find what look bad and take it from there? Should I check the rod bearing on the main engine if I am that close to them?
F-I-T
10-29-2005 06:09:29
 Re: 720D pony and main rods. in reply to DirtJockey, 10-28-2005 20:39:27
DJ:
I have been through several pony transmissions, and yes, many times they do not have proper lube or have been run dry. Now it's my feeling that if you don't have leaking, and everything now runs fine after oil, then it's probably a bad time to tear it apart. "Don't borrow trouble" my grand mother used to say, "It'll come on its own soon enough".
Now, if you do intend to go into that transmission, based on last years prices, you'll probably have $100-$150 in it if you replace the three bearings, a few bushings, some seals, a couple gaskets, and the springs and rollers in the O/R clutch. The overrunning clutch is always forgotten, and there can sometimes be a depression worn where the rollers tend to spin instead of engaging. If you have wear on the star driver lands, you'll need to get that machined, because it is no longer available and must be flat.
On the rods and mains, I would say again, if it runs fine, leave it alone, but if you go that far as to check rod and main bearings, then why not replace the rings, grind the valves, rework the waterpump, etc. and make it a full day? It's certainly your call, but getting that flywheel off of the pony might change your mind in looking at the engine at all.
Remember, too, that the mains and rods are bushed sizes, the rods have no bearings so if you choose to renew, you replace 4 very expensive rods, and the mains can only be adjusted for crank endplay.
You really have to think about how it sounds, if it smokes, knocks, starts hard, etc. For now, I'd be pleased if it started and ran dependably.
Now if you do decide to go ahead and work on the pony, get a proper book and post back here with any questions you might have. They're not too bad to work on, resembling a lawn mower engine in size and complexity.
Frank
dirtjockey
10-29-2005 09:20:31
 Re: 720D pony and main rods. in reply to F-I-T, 10-29-2005 06:09:29
Thanks for the info
