JD Gas Cap Question
John in IN
10-28-2005 18:47:51
I was just wondering if the gas caps on unstyled tractors are vented. I noticed some pressure build up on my '37 A today.
Thanks,
John
Glen in TX
10-28-2005 19:00:55
 Re: JD Gas Cap Question in reply to John in IN, 10-28-2005 18:47:51
Yes they should be vented.
John in IN
10-28-2005 19:07:34
 Re: JD Gas Cap Question in reply to Glen in TX, 10-28-2005 19:00:55
After inspecting the caps on my '37 A and"37 AR, I don't see how they are vented. I think these are original caps.
Need help on this.
Thanks again,
John
Tony W
10-28-2005 19:37:15
 Re: JD Gas Cap Question in reply to John in IN, 10-28-2005 19:07:34
I had the same problem with my 37 AR after buying new caps. Found that the new rubber gasket fit to good and did not allow air to vent. I just cut notches in the rubber where the vents in the cap are located. Look under that rubber and see if yours has holes(4).
Hope this helps some
Glen in TX
10-28-2005 22:26:05
 Re: JD Gas Cap Question in reply to Tony W, 10-28-2005 19:37:15
Tony has the right idea if you have a rubber gasket on it. Originally they had a fiber or cork type gasket. There were also some other non-vented caps for other JDs like combines that will fit and look the same but are not vented caps like you need for the tractors.
