Jd 60 transmission
mark w
11-08-1999 15:44:50
i have a problem with my 60 it jumps out if second gear but the stick does noy come out of its slot its like the gears are sliding apart and the stick is coming out of the fork at the same time has anyone else had this problem thanks m.w.
Mike H
11-08-1999 17:20:38
 Re: jd 60 transmission in reply to mark w, 11-08-1999 15:44:50
The high and low range is the problem you shift this when you go across the middle of the quadrent I think there is a latch on that rail to prevent this is worn
