4030 Starting problem
Oldman4030
10-28-2005 08:30:01
I have a 4030 that has to crank to start. I was cranking on it, it sputtered and now will not turn over. I cleaned up terminals and had batteries checked-both good. When the key is turned on, I do not hear a click but dash lights come on. Turn key further to start and nothing. Any ideas?
Thanks.
G/MAN
10-28-2005 10:29:44
 Re: 4030 Starting problem in reply to Oldman4030, 10-28-2005 08:30:01
In addition to what WTW mentioned, I'd check the battery ground cable where it bolts to the engine. It could be making enough connection to make light-load accessories come on but not enough to handle the juice of starting. Most electrical problems are ground-related.
WTW
10-28-2005 09:01:23
Oldman, The transmission has a neutral start switch that may be open. Wiggle the shift control lever's and see if it will crank. The switch is located on the right side of transmission below shift controls in the shift control rod areas. The other thing that could be a possibility is the starter relay. It is located just above the starter, under hood mounted to the firewall. A 12 volt test light at this location would point you in the direction of your problem. Post back if you need to know more on how to test starting circuit at this location with a test light. DW
