1930 JD D Value
Greg in MO
10-28-2005 07:14:40
third party image
Hey gang,
I found a 1930 D that is in fairly rough shape. Steel in back with a few beat up lugs, round spoke rubber on the front (tires are beyond shot). Tin is pretty beat up and rusted, even the gas tank is dented. It's stuck of course, and the radiator is missing. Tons of surface rust. Obviously it would cost a ton to restore, but might make a parts tractor. Any idea what this thing might be worth? I am thinking the wheels alone are worth a bit, since they are solid and just need some cleaning up.
Thanks!
Greg
jgc
10-28-2005 16:32:44
 Re: 1930 JD D Value in reply to Greg in MO, 10-28-2005 07:14:40
I would offer him the scrap value - 2 1/2 tons x whatever the local scrap rate is per ton at your local scrap yard. I have spent a LOT of money on a 1938 "D" that was in much better shape than this one appears to be in. Many of the internal parts may be badly worn as Glen says.
You might not believe what I found when I got mine apart:
cracked block, cracked head, wrong piston pins, unequal shimming on the conn-rods, gallons of water in the transmission case, many damaged bearings from water corrosion, etc, etc.
Greg in MO
10-31-2005 08:57:12
 Re: 1930 JD D Value in reply to jgc, 10-28-2005 16:32:44
jgc,
I know it would cost way too much to fix this poor old tractor up. I was just trying to decide if the parts value was worth purchasing it. There are some pieces of it that are in decent shape that would be fine with some cleaning, clike the wheels, steering wheel, mag, carb, possibly the block, etc. I hope to one day find a '37 D to go with my A, and this might be a good parts tractor for it. The guy is asking $1k, but I might be able to offer him cash and get it for a bit less. Thanks for the replies...
Greg
Glen in TX
10-29-2005 13:07:24
jgc is very right about the internal parts of Ds being bad if they were outside and worked hard. I was just saying if it is complete and only stuck without other things showing maybe $1000 + or -. Unstyled Ds and Gs complete been bringing those type of prices for a while so don't expect to buy it for scrap price from a wary seller. Use to could buy all those Ds for $50-$100 but not now. The 28 Ds were ones with bad crankshafts. It can take 2 or 3 more Ds if you got water in transmission and bearings and shafts bad and those big differentials do wear out if oil wasn't changed often. Valves and pistons are pricy for Ds also. Good luck.
Glen in TX
10-28-2005 11:03:27
$1000 + If you can get it for less great. Most of these tractors worked a hard life and you don't find many complete or in good shape anymore.
