50 piston replacement
STEVE PHELPS
10-27-2005 16:09:16
Installing new pistons & rings.I removed old pistons from rist pins and left connecting rod on crankshaft.Looks like clearence to install bottom ring is tight.Is this possible ? or do I need to remove a cover some where to access connecting rod.Someone thought it is accessed from top.Looks like more work with power trol & pump in the way. I am trying to slip jugs over compressed rings and piston.
Mike M
10-27-2005 18:19:54
 Re: 50 piston replacement in reply to STEVE PHELPS, 10-27-2005 16:09:16
Anything is possible ? But those engines were made to pull the top off the crankcase,unbolt the rods and push the pistons and rods out the front. You can get in there without pulling the hyd. pump or anything but that top cover,it's tight but I've done it.
STEVE PHELPS
10-28-2005 09:31:23
 Re: 50 piston replacement in reply to Mike M, 10-27-2005 18:19:54
Thanks for the quick response!!!! I went home last night and found the cover. It is tight especially since hood & fuel tank are still intact.My original problem was moisture I think. The block had pits on one side and after tear down discoverd pistons already are 45 oversize. It was rebuilt about 15 years ago. I went to machine shop and was able to go to 90 over. Must be alright I see they make 125.I thought brgs would be ok since problem was not lack of oil psi or oil. I finally purchased rain cap for muffler to replace coffee can.The 50 runs best if stored inside unfortunatly i just moved.I will try the access this weekend. Thanks again!!
Mike M
10-28-2005 10:20:37
 Re: 50 piston replacement in reply to STEVE PHELPS, 10-28-2005 09:31:23
If your engine was not stuck your pits may not be bad enough to worry about. If it was stuck how did you get it apart without unhooking the rods ?
STEVE PHELPS
10-28-2005 10:58:20
 Re: 50 piston replacement in reply to Mike M, 10-28-2005 10:20:37
I had a run issue no power and plugs fouled black soot.backfires and dies.Compression low.I decided to pull head and check for burnt valve and found pits on left cyl block. Is this normal? I might not have my finger on problem yet.I had machine shop grind valves and bore block to 90 over.There response was head & valves not too bad.
Mike M
10-28-2005 11:58:36
 Re: 50 piston replacement in reply to STEVE PHELPS, 10-28-2005 10:58:20
Depends on how deep the pits were I guess if they would hurt much ? That engine may of been stuck before and just cleaned up ? Anyhow it sounds like the pits are history since it's .090. Black soot (dry) just indicates overrich mixture,not getting warmed up,poor ignition. So it sounds like you are still going to have the original problem to deal with. On a freshly rebuilt engine I always like to rebuild the carb. dist. and starter too !
55 50
10-27-2005 16:21:26
That means you have the block removed. Sounds like a rather different way to install rings. It seems a good idea to be sure your connecting rod bearings are OK and that means the rods need to come out. There is an access plate on top of the crankcase to get at the rods. The tractor service manual should be available for this. If not buy one from Deere Publications 1-800-522-7448
