Carbureator on 40 B
red and green
10-27-2005 12:42:45
Don't know much about carbs, but when adjusting the Idle valve it doesn't make any difference whether all the way in or out till it's ready to fall out. The load screw has 1 3/4 turn from starving to flooding. The idle runs better when the choke is about 20% pulled. Any ideas. thanks
jgc
10-28-2005 17:30:24
 Re: Carbureator on 40 B in reply to red and green, 10-27-2005 12:42:45
I would rebuild the carb. You will have to remove all of the brass plugs and get a set of the long drill bits to clean out all of the internal passages. My carb was soaked in commercial carb cleaner, but some of the passages were still blocked. The drill bits drew out a lot of crud - dirt, rust, and fuel deposits.
I removed the brass plugs by heating them very hot with a propane torch until they were a green colour, and carefully removed them with a good screwdriver.
Change everything that's worn out including the throttle bushings, throttle shaft if worn, felt seals, etc, etc.
P Browning
10-27-2005 14:34:54
Here is a short test you can perform to verify performance of the IDLE circuit, and of the LOAD circuit in a single barrel, natural draft JD carburetor. ===== ===== ==
Carburetor Testing -- LOAD & IDLE Pathways A test is conducted to double-check your carburetor's IDLE & LOAD pathways by manipulating the IDLE & LOAD needles. Here is how it goes: (1) CAUTION: This test involves radical adjustment of both the LOAD & IDLE needles. Before starting the engine, observe the position of each needle lever, and count the number of turns OUT that each of the two needles is at so that you can put them back where they were before this test is run. (2) With the tractor running at least at half-full engine speed, turn the LOAD needle all the way in. The engine will continue to run if the IDLE SYSTEM is open, and if it stops running, -- the idle system IS NOT open! Assuming this test is a pass, reset the LOAD needle where is was and go on to the test below. (3) With the engine running at least at half-full engine speed, turn the IDLE needle all the way in. The engine will continue to run provided the LOAD FUEL system is open, however, in this mode, engine operation will be a throttling pattern. As engine speed drops, the governor will open the throttle to draw LOAD FUEL because the idle path is closed. This pattern, however, indicates the LOAD FUEL channel is open & working as it should. If the engine stops running, the LOAD FUEL channel is blocked. ++++
John T
10-27-2005 12:59:12
Red, it sounds like the carbs internal idle circuits may be plugged. Take a look at
Link
If adjusting the idle needle dont matter and she needs choked to idle well, its either the idle circuits plugged or theres a serious Vacuum Leak (leans the fuel/air mixture) like at the throttle shaft bushings or the carbs gasket or the intake manifold, which an unlit propane torch or carb cleaner sprayed around can locate cuz she will speed up n smooth out if its sucked in at the leak.
The ONLY way I get the idle circuits cleaned properly are to disassemble the carb and use heat to loosen then remove the 3 brass drill plugs then use the long No. 40 and No. 53 Drill Bits from Roberts to clean n drill out the passages located behind the brass drill plugs.
May as well rebuild the crab with new throttle shaft bushings if needed and clean the nozzle while in there and inspect the float n needle valve n seat.
I set mine initilaly at 1 turn out for the load needle and 2 for the idle then adjust from there.
John T
old
10-27-2005 12:52:12
My guess would be that the carb needs to be rebuilt. Sounds like you have some junk/rust etc in the idle circuit and or the main also. You might try to spray some carb cleaner down both jets and also clean the jets/needles off with carb cleaner. Open up the drain on the bottom when you do that so the crude can go out the bottom. Then flush it by turning on the gas and let it flow out the bottom for a little bit.
