2020 hydraulic problems
Brady Harmon
10-27-2005 07:37:06
I have a 2020 diesel and this tractor sheared the main hydraulic pump shaft three times. It has a loader on it and I haved checked all the hydraulic system out. Everything checks fine, as far as the relief valves are concerned. I would greatly appreciate any help.
jdemaris
10-27-2005 19:11:54
 Re: 2020 hydraulic problems in reply to Brady Harmon, 10-27-2005 07:37:06
I find it hard to believe that hydraulic pressure is breaking the shaft - not if you have a full size 2.4 or 3 cubic inch pump with the splined input shaft. A little pump with a keyed shaft, maybe. That splined shaft is massive, and I don't believe your tractor has enough power, including the moderate strengh of the coupler, to break it with twisting force. I also don't believe the hydraulic system including all the lines could withstand the high pressure it would take to allow the situation. Also, due to the general nature of the closed-center 8 piston pump, it is highly unlikely. If it indeed did happen, well - first time for seeing anything I guess. I worked on a lot trashed piston pumps over the years on Deere Ag., Industrial, Forestry, and Commercial equipment and never seen it happen. Is your shaft keyed or splined, and does the break show a rotational fracture?
Brady Harmon
10-28-2005 05:56:44
 Re: 2020 hydraulic problems in reply to jdemaris, 10-27-2005 19:11:54
Yes it is a keyed shaft. It has the 2.38 pump. I agree with what you said, finding it hard to believe, because I feel the same way. This has a reman pump on it now. This pump will usually work fine for two to three months, then it breaks again. I believe that every time this shaft has broke, it has broke right after start up and you try to use the loader. It doesn't make a noise one, it just acts like you have lost all hydraulic functions.
jdemaris
10-28-2005 06:43:37
 Re: 2020 hydraulic problems in reply to Brady Harmon, 10-28-2005 05:56:44
That makes sense. I don't think I've seen a 2020 with the little German pump. We didn't sell them that way at our dealership. I'm not sure if if the choice of pumps was optional. We DID have many 1020s with the little pumps. Anway, the metric pump has a smaller shaft than the U.S. built 2.4 and 3 cubic inch pumps. As I'm sure you know, main pressure cut-off is controlled by the pump, not something external. It certainly is not a common problem - seems it must be related to the stroke-control valve. If you've had more than one particlar pump do it, that it's just plain weird. Maybe it would save you some money to stick a 2500 PSI relief valve in the output curcuit - I assume the pump shaft can't break at that pressure.
Brady Harmon
10-28-2005 11:33:51
 Re: 2020 hydraulic problems in reply to jdemaris, 10-28-2005 06:43:37
Where would I put the relief valve, in the output curcuit, before the rockshaft? I work for a John Deere dealer and this is the first time I have ever heard of or seen this happen. It has had the pump rebuilt twice after it broke two times and this time I put a reman pump in it because it trashed the old one.
buickanddeere
10-28-2005 17:35:48
 Re: 2020 hydraulic problems in reply to Brady Harmon, 10-28-2005 11:33:51
If the pumps are fine then alignment or some chunks of floating debris are at fault.
Roy Suomi
10-27-2005 18:25:27
You still have a problem with a relief valve somewhere. If it were popping off as needed , it wouldn't cause breakage as you stated.If you still can't find the problem, I would install an extra relief valve right off the pump output line back to reservoir.
Bob
10-27-2005 18:46:26
 Re: 2020 hydraulic problems in reply to Roy Suomi, 10-27-2005 18:25:27
The 2020 is a closed-center system, and has no conventional relief valve.
What part, specifically, are you breaking in the "pump drive"?
There could be a problem with worn splines, or some type of misalignment, or perhaps something is wrong with the stroke control valve on the pump. Have you done a pressure check?
