JD 450B Stalling
C B
10-26-2003 13:20:38
25 year old John Deere 450B diesel loader stalls after running for a couple of minutes - or less. Replacing fuel filters, transfer pump,fuel,and bleeding the fuel system didn't help. Found that disconnecting the fuel return line at the engine stopped the stalling problem. Reconnecting the return line causes the loader to again stall after a few minutes. Replaced/air-purged the return line. Problem still there. Anyone have any ideas. Thanks
Smokechaser
03-18-2006 20:37:20
 Re: JD 450B Stalling in reply to C B, 10-26-2003 13:20:38
I had a similar problem with a JD450B dozer stalling after running for a few minutes. It would run great for 2 or 3 min then it would start to surge as if it was running out of fuel. I replaced the fuel filters and bled the system, same thing! I disconected the metal fuel line coming from the fuel tank to the transfer pump. The fuel trickled out as if there was a blockage in the line. I used compressed air and blew the line out at the disconnected fitting back to the tank. The fuel then flowed with no blockage. Apparently some sludge or debris was partially blocking the line. I reconnected the fuel line to the lift pump, and the engine runs fine now. Probably need to vacuum the tank to get all the junk out, I"ll wait till the fuel runs low to do that. Was not an expensive fuel pump problem as I had expected. Thanks YT for the ideas.
Jim B
10-27-2003 04:11:04
C B,when you disconnected the return line and it ran did you have the fitting on pump that return line attaches to in or out?There is a glass checkball in fitting that can plug with debris that will keep engine from running.Jim B
CB
10-27-2003 16:41:12
 Re: Re: JD 450B Stalling in reply to Jim B, 10-27-2003 04:11:04
Thanks for replying.
The line was disconnected between the "check-valve" and the injectors. This afternoon, my son removed the "check-valve", cleaned it and re-installed. Runs fine - for the present. It's probable the injector pump will need to rebuilt or replaced before long. Can someone tell me how the fuel return system is supposed to work? Also, can someone tell me how to remove and install the pump without messing up timing?
Thanks again.
Jonathan
10-26-2003 15:18:23
Thats indicative of a component in the injection pump coming apart...remedy is to get a replacement rebuilt pump or have that one rebuilt....
CB
10-27-2003 17:00:09
 Re: Re: JD 450B Stalling in reply to Jonathan, 10-26-2003 15:18:23
Cleaning the fuel return check valve (refer to Jim B's followup) stopped the problem for now, but I expect the pump will need to be rebuilt or replaced before long. Can you tell me how to remove and reinstall the pump without creating a timing problem?
Jim B
10-28-2003 05:27:26
 Re: Re: Re: JD 450B Stalling in reply to CB, 10-27-2003 17:00:09
CB,I have seen those checkballs cleaned and inj.pump would last several more hrs.The debris is probably the govenor ring and as long as you can control the rpm's if it was mine I'd run it.Jim B
